DIFF event config problem
Hi.
In the Events Config panel I set the DIFF value to start or stop the OUT0 (Relay).
I set it to start the relay when the DIFF value is above 6 degrees and stop the relay when the DIFF is above 30 degrees.
After a lot of checks the relay starts correctly when the DIFF above 6 degrees but there is problem.
For some unknown reason the relay goes off after a while.
The DIFF calculates the difference between INP7 and INP6 (DIFF=INP7-INP6)
The funny thing is that if the INP7 goes above 30 degrees the relay goes OFF.
In the configuration I have NO configs for the INP7 or INP6.... only for the DIFF.
Any suggestions?
The Hardware is version 2 and firmware is 3.10 (latest).
