INP3D & Energy measure - FW error?
Hi developers,
I have LAN Controller HW 1.2, FW latest - 3.22.
I would like to measure the energy (kWh). I'm using the INP3D input, but it works wrong.
When I shorted INP3D to GND, the counter (kwh) didn't stop count. I think that counter should count the pulses. I didn't generate any pulse.
You can see it the video file - https://dl.dropboxusercontent.com/u/62359529/LAN.avi
Could you answer to my questions?
1) Is it mistake?
2) Could you create new firmware with correct function?
3) How much pulses could it catch in 1 second max? 3-5 pulses/1s ? Is it possible to catch faster pulses or should I use the HW divider?
Thank you, I will wait for your answers
Pavel
Hi,
I find FW 3.29P - http://www.pvmonitor.pl/sprzet.php
It has 2 counters. It looks better. I will test it.
@PavelV
Possibly go back to version, 3.18 version 3.22 has a bug. I had the same
