NonBoot LanControl
Hello. I have Lan controller. But It doesnt boot. Its only green led blinking . No eth answer ping, arp etc. all tftp update fail.
Is any chance to recovery board to normally function ??
Thanks for help.
grenn led blink, means that is it in bootloader mode. You try simply put by tftp? What soft was before upgrade?
It have a "home" version 3.21. i tryied put in controler "isp" version. But always fail start upload by tftp (connection timeout) . Now controler wont respond anyway.
If you have enabled DHCP, use standard IP 192.168.100, if not, use last IP.
Thanks. It works with my IP and WinXP.
