Nowy soft 3.09 (wersja home)
#21
shorty1965 napisał(a):restart to default settings?
can i do that by http? remote, because the modul is mounted anywhere
br
Shorty
No, only by push button
But, tel me waht older vesion you had before? Maby I chnege some in next sofware.
Try othre web browser etc. rekonq. In firefox run console error and tell waht error you have.
Hi
I get the following, please translate
It works from Android phone, and not IE9 or Firefox
The version before was 2.39
[06:03:16.270] GET http://192.168.1.122:882/ [HTTP/1.1 200 OK 49ms]
[06:03:16.271] GET http://192.168.1.122:882/mchp.css [HTTP/1.1 200 OK 34ms]
[06:03:16.272] GET http://192.168.1.122:882/mchp.js [HTTP/1.1 200 OK 119ms]
[06:03:16.303] Fehler beim Verarbeiten des Wertes für 'float'. Deklaration ignoriert. @ http://192.168.1.122:882/mchp.css:50
[06:03:16.393] Die Zeichenkodierung des HTML-Dokuments wurde nicht deklariert. Das Dokument wird in manchen Browser-Konfigurationen mit verstümmeltem Text dargestellt, wenn das Dokument Zeichen außerhalb des US-ASCII-Bereichs enthält. Die Zeichenkodierung der Seite muss im Dokument oder Transferprotokoll deklariert werden. @ http://192.168.1.122:882/
[06:03:16.480] GET http://192.168.1.122:882/st2.xml [HTTP/1.1 200 OK 53ms]
[06:03:16.483] nicht wohlgeformt @ http://192.168.1.122:882/st2.xml:34
[06:03:16.584] TypeError: d is null @ http://192.168.1.122:882/mchp.js:409
[06:03:16.955] GET http://192.168.1.122:882/st0.xml [HTTP/1.1 200 OK 38ms]
Also why I saw that additional inputs INP10,11 and DTH11?
is that a new function?
BR
Shorty
.png   new.png (Rozmiar: 565.98 KB / Pobrań: 4,487)
.png   new.png (Rozmiar: 565.98 KB / Pobrań: 4,536)
.png   new.png (Rozmiar: 565.98 KB / Pobrań: 4,441)
.png   new.png (Rozmiar: 565.98 KB / Pobrań: 4,524)
reset to default didnt change something, I flashed back to 2.36 then it was working again.
then again upgrade to 2.42 works now
I had the same troubles from version 3.06 to 2.42 or 2.39 to 2.42
I have more units running, one is working fine after upgrade to 2.42
is there any possibility to save the config / backup?
whats about a https connection, is there any plan?
Czy starsze LK (S/N 1700 - 1750) jest sens uprgade`ować do 3.06?
Na jednym spróbowałem i nie działa odczyt SNMP i coś tam jeszcze nie pamięta.
Mam tych starych po instalowanych jeszcze kilka i nie wiem czy je ruszać.
Z drugiej strony w niektórych przydałoby się sześć odczytów z DS-ów.
W domu mam dwa LK i na tym nowszym (sn2518) wszystko chyba działa.
a robiles restart do domyslnych ustawień?
Pomogło, dzięki.
A teraz czeka mnie wpisywanie z ręki wszystkich ustawień na kilku LK Sad
Kornel
jak chcesz to poczekaj i nie wgrywaj w innych, napisz tylko jaki masz na nich aktualny soft?
shorty1965 napisał(a):is there any possibility to save the config / backup?
Config backup, maby, but I don't now when. But wait, I add new soft without need restart to default.
DTH11 is sensor temp and humidity
wilkxt napisał(a):jak chcesz to poczekaj i nie wgrywaj w innych, napisz tylko jaki masz na nich aktualny soft?
Soft mam 2.39 lub 3.01 - na co mam poczekać?
Sprawdzałem na tym jednym LK kilka razy i odczyt SNMP przestaje działać jak w Events Config zaznaczę wysłanie maila w INP1D.
Jak odznaczę i zrestartuję to znowu działa. Dziwne. Stan na INP1D jest cały czas HIGH.
bedzie wersja z poprawkami w przyszlym tygodniu
