Problem z e-mail
Ustawienie serwera e-mail bez szyfrowania. Zwykłe uwierzytelnianie na porcie 587 dla SMTP. Poniższy komunikat pojawia się w logach serwera pocztowego.
2023-11-02 SMTP protocol error in "AUTH LOGIN" H=[185.xx.xx.xx] AUTH command used when not advertised
"The 503 AUTH command used when not advertised essentially explains itself, it didn't offer the client the option to use the AUTH command. This is most likely because the client used HELO rather than EHLO (which I would note you used when you did your telnet test"
aktualnie email dziła tylko z TLS
(11-02-2023, 10:03 PM)Pawel napisał(a): Ustawienie serwera e-mail bez szyfrowania. Zwykłe uwierzytelnianie na porcie 587 dla SMTP. Poniższy komunikat pojawia się w logach serwera pocztowego.
(11-25-2023, 11:19 PM)wilkxt napisał(a): aktualnie email dziła tylko z TLS
bez szyfrowania to chyba ban murowany w googlu?
gmail tylko z szyfrowaniem
This is a classic. It's so frustrating when you think you've got everything configured, and then a simple HELO vs. EHLO trips you up. Been there, done that, felt like a complete Snow rider trying to debug it for hours. Good catch on realizing the server wasn't advertising AUTH!
