Home Assistant - Unknown error occurred
Dzień dobry !
W trakcie dodawania przez interfejs www uzupełniając: ip, port, login, hasło, czas, otrzymuje komunikat powodujacy brak możliwości dodania urządzenia do HA.
Czy ktoś wie jak rozwiązać problem z dodaniem urządzenia ?
Skonfiguruj swoje urządzenie tinycontrol, aby zintegrować je z Home Assistant.
  • HA:  2024.12.0 lub 2024.12.1
  • Plugin: tinycontrol_home-assistant_0.11.2.zip
  • LK4  SW 1.18a | HW 1.0
W logach:
POWER_VOLT_AMPERE_REACTIVE was used from tinycontrol, this is a deprecated constant which will be removed in HA Core 2025.9. Use UnitOfReactivePower.VOLT_AMPERE_REACTIVE instead, please report it to the author of the 'tinycontrol' custom integration
Rejestrator: aiohttp.server
Źródło: /usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py:451
Error handling request
Traceback (most recent call last):
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 480, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 222, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
    return await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 122, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 367, in async_configure
    result = await self._async_configure(flow_id, user_input)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 414, in _async_configure
    result = await self._async_handle_step(
        flow, cur_step["step_id"], user_input
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 517, in _async_handle_step
    result: _FlowResultT = await getattr(flow, method)(user_input)
  File "/config/custom_components/tinycontrol/config_flow.py", line 60, in async_step_user
    await self._get_tinycontrol_mac(raise_on_progress=False)
  File "/config/custom_components/tinycontrol/config_flow.py", line 123, in _get_tinycontrol_mac
    data = await tiny_device.async_get_all()
AttributeError: 'NoneType' object has no attribute 'async_get_all'
Wygląda to skomplikowanie (pewnie nie jestem ekspertem). Czekam na odpowiedź ekspertów.
