huawei - wszystkie inwertery
wpinanie licznika  L3F1946  do systemu huawei do pinow  7,9 w złączu komunikacyjnym falownika by  zmusić go do pracy offgrid lub backup mode lub magazynu sun2000
licznik musi mieć ustawienia by go znalazł falownik  addr: 11, baud: 9600, data: n.8.1, port: rtu
Po podłączeniu do falownika licznik wykrywany jest jako DTSU666-H.
json do LK
{"name":"L3F1946-4P","bitrate":0,"parityBit":0,"stopBit":1,"delayBetweenReads":0.1,"readings":[{"name":"A phase voltage","unit":"V","divisor":100,"address":0,"functionCode":4,"variableType":2,"endian":0},{"name":"B phase voltage","unit":"V","divisor":100,"address":2,"functionCode":4,"variableType":2,"endian":0},{"name":"C phase voltage","unit":"V","divisor":100,"address":4,"functionCode":4,"variableType":2,"endian":0},{"name":"A phase current","unit":"A","divisor":100,"address":12,"functionCode":4,"variableType":2,"endian":0},{"name":"B phase current","unit":"A","divisor":100,"address":14,"functionCode":4,"variableType":2,"endian":0},{"name":"C phase current","unit":"A","divisor":100,"address":16,"functionCode":4,"variableType":2,"endian":0},{"name":"Total energy <","unit":"kWh","divisor":100,"address":52,"functionCode":4,"variableType":2,"endian":0},{"name":"Total energy >","unit":"kWh","divisor":100,"address":54,"functionCode":4,"variableType":2,"endian":0},{"name":"A phase view","unit":"kW","divisor":100,"address":34,"functionCode":4,"variableType":2,"endian":0},{"name":"B phase view","unit":"kW","divisor":100,"address":36,"functionCode":4,"variableType":2,"endian":0},{"name":"C phase view","unit":"kW","divisor":100,"address":38,"functionCode":4,"variableType":2,"endian":0},{"name":"Total view","unit":"kW","divisor":100,"address":24,"functionCode":4,"variableType":2,"endian":0},{"name":"APM  [Total]","unit":"Wh","divisor":10,"address":290,"functionCode":4,"variableType":0,"endian":0},{"name":"APM total","unit":"WH","divisor":10,"address":280,"functionCode":4,"variableType":0,"endian":0},{"name":"Max line V","unit":"V","divisor":10,"address":1557,"functionCode":4,"variableType":0,"endian":0},{"name":"Max month >","unit":"W","divisor":10000,"address":1551,"functionCode":4,"variableType":0,"endian":0},{"name":"Max month <","unit":"W","divisor":10000,"address":1552,"functionCode":4,"variableType":0,"endian":0},{"name":"Max month power","unit":"W","divisor":10,"address":1540,"functionCode":4,"variableType":2,"endian":0}]}
gdyby ktoś potrzebował dysponuje pełną rozpiska komunikacji - pisać prv
