Lan controller after a reset can not connect over the web
Before that I lan controller from tinycontrol.pl he had on port 197. But I needed to reset the controller for uploading the newer firmware (before that it was not). After a reset (10s), but my router lists the DHCP put at 192.168.0.110, so over the web to get it. I also tried the default 192.168.0.100, but it is my PC.
I tried to go through without a router. On my PC tossed IP 192.168.0.101 (255.255.255.0) and hoped that the default IP LAN Controller 192.168.0.100 help with the connection. Unfortunately again I get there.
Still do what I do?
default IP is 192.168.1.100
