(12-31-2019, 09:40 AM)wilkxt napisał(a):
(12-30-2019, 08:00 PM)mavar napisał(a): [/color]-> I found these "docs" more specifying mentioned sensor, but I dont know, if there are sufficient...  https://github.com/riteshRcH/waterproof_...2YYxx_v1.0
It should work with firmware 1.21
I can confirm now - Its working with FW 1.23
Hello
Just a short question. Do you plan to increase display funcionality to cover also bigger I2C displays like for example these two:
https://www.ebay.com/itm/Blue-1-54-128X6...3648290642
https://www.ebay.com/itm/2-42-inch-White...3307973871
I hope (but maybe Im wrong - sorry) limitation is only in I2C address which is now fixed and set only for 0.96 display.
Thank you for you time
Martin
in SSD1309 you mau set
DC connect to GND, adress is 0x3C, the same as SSD1306
DC connect to 3,3Vcc, adress is 0x3D
So maby it will work
(03-26-2020, 12:16 PM)wilkxt napisał(a): in SSD1309 you mau set
I thought address of recommended/supported 0.96 OLED display is 0x78 or 0x7A so it must be changed somewhere in LK3 firmware before connection of different display unit.
Your reply sounds much better. So, I'll try and let you know
Thank you
0x78>>1 = 0x3C
People give i2C addresses wrong, the address is 7 bits and the last bit is write or read. Once the address is given with this bit, and the second time not, and therefore we have 0x78 or 0x3C
Załączam nowy soft tylko LK3.5+ v 1.24
.zip   lk3_7_firmware_1_24.zip (Rozmiar: 460.54 KB / Pobrań: 578)
- opcje wyłączenia strony logowania, zakładka "Settings ->Automatic sign in" prawy górny róg strony
- komendę na restart LK przy pomocy mqtt
- nowe urządzenie(Epever tracer1210- ładowarka solarna) do obsługi przez modbus
- 3 dodatkowe pola z numerami telefonów do wysylania smsów. W zdarzeniach sms1 ->msg1 i nr tel1, sms2->msg2 i nr tel2, itd.
poprawilem w powyzszym sofcie opis pol z smsami, Ci którzy pobrali plik wczoraj mogą sobie zaktualizować do obecnego
(04-01-2020, 03:55 PM)wilkxt napisał(a): Załączam nowy soft tylko LK3.5+ v 1.24
Coś chyba nie tak z tym softem.
Nie widzę tych zmian co piszesz, poza tym nie mam w Zdarzeniach tych pól z SMSami
[Obrazek: sms.png]
Nie mam restartu przez MQTT i na dodatek po wpisaniu numeru w Porcie szeregowym do bramki i klikając zapisz. Nie wysyła testowego SMSa ERROR i po wyjściu i wejściu ponownie w zakładkę Port szeregowy znika numer.
[Obrazek: sms.png]
pola z smsami sa w ustawienich gsm, doszły tam 4 nowe pola z numerami smsow, ktre odpowiadaja zdarzenia
A dało by się zrobić tak albo jak kto woli Smile Bo jak chciałbym tego samego smsa wysłać do żony i dziecka to już po powiadomieniach bo uciekają 3 i jedno mi zostaje tylko.
[Obrazek: s0s.png]
(04-03-2020, 01:11 PM)marcinb napisał(a): A dało by się zrobić tak albo jak kto woli Smile Bo jak chciałbym tego samego smsa wysłać do żony i dziecka to już po powiadomieniach bo uciekają 3 i jedno mi zostaje tylko.
[Obrazek: s0s.png]
musimy się zastanowic jak to najlepiej rozwiazac
