Hello PluginLibrary!
SNMP server
I have problem with INPD1-3 on controller V2 firmware 2.15.
On the INPD4 is now the consumption meter and it works perfectly. I'm reading the value of kWh from CACTI by SNMP.
On another input (INPD1-3) is now connect another pulse unit and If I sand the pulse on INPD1,2 or 3 than the SNMP is ca. 5 min off .
Same problem is when is shortly the jumper bet between GND and INPD1 …3.
I will read the address from INMP3 in to CACTI and in CACTI is my second counter.
Can somebody help me with my problem?
