http status get - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler - wersje oprogramowania (https://forum.tinycontrol.pl/forumdisplay.php?fid=4) +--- Wątek: http status get (/showthread.php?tid=97) |
http status get - leonardo - 10-28-2012 salve, first of all many thanks for your work I'm currently using http requests to SET output ports status: http://192.168.1.100/outs.cgi?out0=0 ### "=0" passed ---> cgi set out0 on http://192.168.1.100/outs.cgi?out0=1 ### "=1" passed ---> cgi set out0 off ... but, can you please consider adding a way to GET output ports status ? for example: http://192.168.1.100/outs.cgi?out0 ### nor "=0" neither "=1" passed ---> cgi will reply out0 port status ! ... it'll be marvelous if you could consider adding ALL ports status, input and output: http://192.168.1.100/status.cgi?inp9 ### cgi will reply analog input inp9 status ! http://192.168.1.100/status.cgi?inp4d ### cgi will reply digital input inp4d status ! http://192.168.1.100/status.cgi?out0 ### cgi will reply output out0 port status ! please let us know ... lg Re: http status get - wilkxt - 10-31-2012 Maybe we add this function in home version without watchdog? Do you use watchdog? Re: http status get - leonardo - 10-31-2012 waiting for your new managed poe switch we are now planning to use lan controllers + 4 relays extension boards to remotely monitor/control our radio base stations powering so ping watchdog is obviously a very important feature ... post scriptum: ... it'll be extremely marvelous if you could also consider reporting ALL ports status ... TOGETHER: http://192.168.1.100/status.cgi ### no arg passed ---> cgi will reply ALL port status ! returned page may be: inp1d=LOW, ..., inp4d=HIGH, inp1=0.0, ..., inp9=N/A, out0=ON, ..., out4=OFF, ... off topic: I asked my usual reseller for your new managed poe switch ... no reply ! when do you think we'll enjoy using your new managed poe switch ? when/where could we buy it ? lg Re: http status get - leonardo - 10-31-2012 waiting for your new managed poe switch we are now planning to use lan controllers + 4 relays extension boards to remotely monitor/control our radio base stations powering so ping watchdog is obviously a very important feature ... post scriptum: ... it'll be extremely marvelous if you could also consider reporting ALL ports status ... TOGETHER: http://192.168.1.100/status.cgi ### no arg passed ---> cgi will reply ALL port status ! returned page may be: inp1d=LOW, ..., inp4d=HIGH, inp1=0.0, ..., inp9=N/A, out0=ON, ..., out4=OFF, ... off topic: I asked my usual reseller for your new managed poe switch ... no reply ! when do you think we'll enjoy using your new managed poe switch ? when/where could we buy it ? lg Re: http status get - wilkxt - 11-02-2012 leonardo napisał(a):I asked my usual reseller for your new managed poe switch ... no reply !POE swicth is now in shoop, you may buy it. Now POE switch has soft version without VLAN, but next week will be firmware with VLAN. RE: http status get - TheresaVaughn - 10-16-2020 A quilt is followed for the parts for the team. The signs of the ambit and bestessays.com are held for all chips. The plant is filed for the approval of the rounding spaces for goals. |
