HTTP Client settings - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V3 (https://forum.tinycontrol.pl/forumdisplay.php?fid=27) +--- Wątek: HTTP Client settings (/showthread.php?tid=920) |
HTTP Client settings - octavvian - 10-19-2018 Hi, in Version: 1.49b6, HTTP Client settings are not retained after a reboot/restart. Any idea why? Thanks. Re: HTTP Client settings - octavvian - 10-24-2018 Echo?! :? Re: HTTP Client settings - wilkxt - 10-26-2018 We check this Re: HTTP Client settings - jwmega - 10-26-2018 octavvian post_id=15860 time=1539960308 user_id=6211 napisał(a):Hi, in Version: 1.49b6, HTTP Client settings are not retained after a reboot/restart. Any idea why?Did you press "Save" before you did reboot/restart? Re: HTTP Client settings - octavvian - 10-30-2018 Hi, I think so..... still no retain. Re: HTTP Client settings - wilkxt - 10-30-2018 1.Maby you have to long string? 2. You change http url1 or url2 or url3? Re: HTTP Client settings - octavvian - 11-01-2018 Tried all off them... the string is : "aircon/set_control_info?pow=1&mode=3&stemp=26&shum=0&f_rate=A&f_dir=0" P.S. it worked in previous versions.... Re: HTTP Client settings - octavvian - 11-02-2018 And now "Server Error (500) on MQTT ats.pl server"... |
