Forum tinycontrol
Connecting LCD to LK3 using UART - Wersja do druku
+--- Dział: LanKontroler V3 (https://forum.tinycontrol.pl/forumdisplay.php?fid=27)
+--- Wątek: Connecting LCD to LK3 using UART (/showthread.php?tid=780)
Connecting LCD to LK3 using UART - ghorvat - 03-10-2017
Hello everyone! My name is Goran and I am new to the forum!
I would like to know would it be possible to connect an LCD display to LK3 ?
I see that the LCD is not included in the accessories, but I would like to know would it be possible to connect an LCD using the UART present on the LK3? In this case, I would program a micro controller to talk to the LK using UART, and display the parameters such as IP address, input values etc. on the display.
My question is: what parameters could be accesses using the UART on the LK3? The manual only states "console preview"?
Thanks!
Re: Connecting LCD to LK3 using UART - wilkxt - 03-11-2017
Hi
we plan add LCD to lk3 by SPI port.
BY uart console you only view state LK3 and what now doing, etc. send http client, or mqtt
Re: Connecting LCD to LK3 using UART - ghorvat - 03-13-2017
When can we expect this to be integrated in LK3?
Re: Connecting LCD to LK3 using UART - wilkxt - 03-20-2017
Propably this month
Re: Connecting LCD to LK3 using UART - ghorvat - 05-04-2017
Hello
Any news regarding the firmware upgrade to support LCD?
Re: Connecting LCD to LK3 using UART - wilkxt - 05-04-2017
We added support to OLED 128*64 0.96 inch 4pin OLED Module SSD1306 Drive,I2C
like this https://pl.aliexpress.com/item/Wholesale-0-96-inch-4pin-White-OLED-Module-SSD1306-Drive-IC-128-64-I2C-IIC-Communication/32658908775.html?isOrigTitle=true.
As we finish the tests, we will provide a new firmware
That would be great!
Also, do you plan to integrate support for barometric air pressure sensor (for example BMP180) ?
Re: Connecting LCD to LK3 using UART - wilkxt - 05-07-2017
ghorvat napisał(a):That would be great!
Yes we plan add air pressure sensor
