Forum tinycontrol
Backup automat php - Wersja do druku
+--- Wątek: Backup automat php (/showthread.php?tid=3128)
Backup automat php - stAch - 07-28-2025
jeden klik i zapisane nawet 100 backupów z LK3 w różnych lokalizacjach - nic prostszego.
Kod PHP:
<?php
error_reporting
(E_ALL);
parse_str($_SERVER['QUERY_STRING']);
if (isset(
$_GET['cron'])) {
    $_POST['backups'] = 1;
    $_SERVER['REQUEST_METHOD'] = 'POST';
$folder = "backups";
$pattern = '/_(\d{4}-\d{2}-\d{2})_setting\.bin$/';
// Usuwanie plików (na podstawie daty z POST)
if ($_SERVER['REQUEST_METHOD'] === 'POST' && isset($_POST['date'])) {
    $dateToDelete = $_POST['date'];
    foreach (scandir($folder) as $file) {
        if (preg_match($pattern, $file, $matches) && $matches[1] === $dateToDelete) {
            unlink($folder . DIRECTORY_SEPARATOR . $file);
    echo json_encode(['success' => true]);
    exit;
// Backup i lista
if ($_SERVER['REQUEST_METHOD'] === 'POST' && isset($_POST['backups'])) {
    $messages = "";
    // ? Dane logowania globalne
    $globalUser = 'admin';
    $globalPass = 'xxxxxxx';
    // ? Lista hostów
    $sources = [
        ['ip' => '192.168.1.20', 'port' => 97,  'name' => 'SOL'],
        ['ip' => '192.168.1.20', 'port' => 98,  'name' => 'CWU', 'user' => 'admin', 'pass' => 'xxxxxx'],
        ['ip' => '192.168.1.20', 'port' => 99,  'name' => 'GSM'],
        ['ip' => '192.168.1.20', 'port' => 100, 'name' => 'PCO'],
    $remotePath = "/lk3_settings.bin";
    $backupDir = __DIR__ . '/backups';
    if (!is_dir($backupDir)) {
        mkdir($backupDir, 0777, true);
    $date = date("_Y-m-d");
    foreach ($sources as $source) {
        $ip   = $source['ip'];
        $port = $source['port'];
        $name = $source['name'];
        $user = $source['user'] ?? $globalUser;
        $pass = $source['pass'] ?? $globalPass;
        $url = "http://$ip:$port$remotePath";
        $auth = base64_encode("$user:$pass");
        $opts = [
            "http" => [
                "method" => "GET",
                "header" => "Authorization: Basic $auth\r\n"
        $context = stream_context_create($opts);
        $content = @file_get_contents($url, false, $context);
        if ($content === false) {
            $messages .= "<div>? Błąd pobierania: $url</div>";
            continue;
        $filename = "{$name}{$date}_setting.bin";
        $filepath = $backupDir . '/' . $filename;
        if (file_put_contents($filepath, $content) !== false) {
            $messages .= "<div>✔ Zapisano: $filename</div>";
        } else {
            $messages .= "<div>? Błąd zapisu: $filename</div>";
    // ? Lista backupów
    ob_start();
    $groups = [];
        if (preg_match($pattern, $file, $matches)) {
            $date = $matches[1];
            $groups[$date][] = $file;
    if (empty($groups)) {
        echo "<p>Brak plików.</p>";
    } else {
        foreach ($groups as $date => $files) {
            echo "<div class='group' data-date='" . htmlspecialchars($date) . "'>";
            echo "<button class='delete-btn' onclick='deleteGroup(\"$date\")'>Usuń grupę</button>";
            echo "<h3>" . htmlspecialchars($date) . "</h3>";
            foreach ($files as $file) {
                $fileEnc = rawurlencode($file);
                echo "<div class='file'>";
                echo htmlspecialchars($file);
                echo " <a class='download' href='backups/$fileEnc' download>Pobierz</a>";
                echo "</div>";
            echo "</div>";
    $html = ob_get_clean();
    echo json_encode([
        'success' => true,
        'html' => $html,
        'messages' => $messages
    exit;
// Pierwsze wczytanie listy
$groups = [];
foreach (
<!DOCTYPE html>
<html lang="pl">
<head>
    <meta charset="UTF-8">
    <title>LK3 Backups</title>
    <style>
        body { font-family: Arial; padding: 20px; }
        .group { border: 1px solid #ccc; padding: 10px; margin-bottom: 20px; border-radius: 5px; }
        .group h3 { margin: 0 0 10px 0; }
        .file { margin-left: 20px; }
        .delete-btn {
            background: #d00;
            color: white;
            border: none;
            padding: 5px 10px;
            float: right;
            cursor: pointer;
        .download {
            background: #4CAF50;
            color: white;
            padding: 3px 8px;
            margin-left: 10px;
            text-decoration: none;
            border-radius: 3px;
        .download:hover {
            background: #45a049;
        .info {
            margin-top: 20px;
            padding: 10px;
            background: #f9f9f9;
            border: 1px dashed #aaa;
            white-space: pre-wrap;
        button.refresh {
            background: #007bff;
            color: white;
            border: none;
            padding: 6px 12px;
            cursor: pointer;
    </style>
</head>
<body>
<h1>Kopie zapasowe LK3 wg. daty</h1>
<div id="backup-list">
<?php if (empty($groups)): ?>
    <p>Brak plików.</p>
<?php else: ?>
    <?php foreach ($groups as $date => $files): ?>
        <div class="group" data-date="<?= htmlspecialchars($date) ?>">
            <button class="delete-btn" onclick="deleteGroup('<?= $date ?>')">Usuń grupę</button>
            <h3><?= htmlspecialchars($date) ?></h3>
            <?php foreach ($files as $file): ?>
                <div class="file">
                    <?= htmlspecialchars($file) ?>
                    <a class="download" href="backups/<?= rawurlencode($file) ?>" download>Pobierz</a>
                </div>
            <?php endforeach; ?>
        </div>
<?php
endif; ?>
</div>
<div class="info">
    <button class="refresh" onclick="getBackups()">? Aktualizuj (pobierz backupy)</button>
</div>
<script>
function deleteGroup(date) {
    if (!confirm(`Czy na pewno chcesz usunąć wszystkie pliki z datą ${date}?`)) return;
    fetch('', {
        method: 'POST',
        headers: {'Content-Type': 'application/x-www-form-urlencoded'},
        body: 'date=' + encodeURIComponent(date)
    .then(res => res.json())
    .then(data => {
        if (data.success) {
            document.querySelector(`.group[data-date="${date}"]`).remove();
        } else {
            alert('Błąd przy usuwaniu.');
function getBackups() {
    document.querySelector('.info').innerHTML = '⏳ Trwa pobieranie...';
    fetch('', {
        method: 'POST',
        body: 'backups=1'
    .then(data => {
        if (data.success) {
            if (data.html) {
                document.querySelector('#backup-list').innerHTML = data.html;
            if (data.messages) {
                document.querySelector('.info').innerHTML = data.messages;
            } else {
                document.querySelector('.info').innerHTML = '✅ Gotowe.';
        } else {
            document.querySelector('.info').innerHTML = '❌ Błąd przy pobieraniu.';
    .catch(err => {
        console.error('Fetch error:', err);
        document.querySelector('.info').innerHTML = '❌ Wystąpił błąd sieci.';
</script>
</body>
</html>
zapisać na serwerze ...edytować ip i porty do pobrania plików backups oraz globalne hasło i usera czyli fragment kodu poniżej.
    $globalUser = 'admin';    //globalny user
    $globalPass = 'pass';     //globalne haslo
    // ? Lista hostów
    $sources = [
        ['ip' => '192.168.1.100', 'port' => 80,  'name' => 'SOL'],
        ['ip' => '132.138.3.220', 'port' => 98,  'name' => 'CWU', 'user' => 'user', 'pass' => '1234'],
        ['ip' => '132.138.3.220', 'port' => 99,  'name' => 'GSM'],
        ['ip' => '132.138.3.220', 'port' => 100, 'name' => 'PCO'],
jeśli wszystkie maja takie samo to nie musicie go podawać dla każdego z osobna wystarczy je podać jako globalne
skrypt pobiera zarówno z lokal ip:80 jak i po external ip:port można dodać go do crona by sam cyklicznie robił kopie na serwerze.
0 2 * * * curl -s "http://twojadomena.pl/backup.php?cron=1" > /dev/null 2>&1
pytania lub problemy chętnie p/odpowiem...
