Forum Tiny Control Solution
How to use INPD[1-4] - Wersja do druku
+--- Dział: LanKontroler V4 (https://forum.tinycontrol.pl/forumdisplay.php?fid=36)
+--- Wątek: How to use INPD[1-4] (/showthread.php?tid=3093)
How to use INPD[1-4] - stsc4711 - 03-28-2025
I want to use INPD1 to count a reed switch. Unforntunately there is no documentation for wiring this input.
Is there an interal pull-down or pull-up resistor connected to this input?
Does it work if i connect the reed switch to +5V and INPD or do I need to add pull-down or pull-up resistor externally?
RE: How to use INPD[1-4] - jennikim266 - 04-09-2025
Your writings stick out to me since the content is interesting and simple to understand. Even though I've read a lot of websites curve rush, I still like yours more. Your essay was interesting to read. I can understand the essay better now that I've read it carefully. In the future, I'd like to read more of your writing.
