Wilo water level sensor 4-20mA - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V3.5 (https://forum.tinycontrol.pl/forumdisplay.php?fid=28) +--- Wątek: Wilo water level sensor 4-20mA (/showthread.php?tid=2555) |
Wilo water level sensor 4-20mA - JCh - 10-03-2022 Hey all, I would like to ask if it is possible to use the Wilo water level sensor together with the Tinycontrol Converter for 4-20mA sensors and what the wiring should be. Sensor https://wilo.com/cz/cs/Produkty-a-aplikace/cs/prislusenstvi/elektricke-prislusenstvi/snimac-hladiny?t=0#c40288a8a5484f69a0154c8a86826317dTL4_range_advantages Converter https://tinycontrol.pl/en/accessories/boards/converter-inpa/ Regards JCh RE: Wilo water level sensor 4-20mA - notek - 10-10-2022 If you like to use this sensor and converter with LAN Controller v3/5 it will show value. But it will be not pressure in bars, but approximated mA |
