Electricity meter pulse reading - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V3 (https://forum.tinycontrol.pl/forumdisplay.php?fid=27) +--- Wątek: Electricity meter pulse reading (/showthread.php?tid=2494) |
Electricity meter pulse reading - v4v - 06-20-2022 Hi, it is possible to read pulses from LE-02d MID electricity meter? (SW 1.49d | HW 3.8) https://www.fif.com.pl/en/usage-electric-power-meters/268-electrici-energy-meter-le-02d.html In datasheet I see: Connection voltage SO + SO- max. 30 V DC And digital inputs are up to 20V. So I guess no. Maybe resistor voltage divider? RE: Electricity meter pulse reading - wilkxt - 06-23-2022 (06-20-2022, 08:18 PM)v4v napisał(a): Hi, it is possible to read pulses from LE-02d MID electricity meter? (SW 1.49d | HW 3.8) you can add a 510om resistor to the INPDx input and it should be ok RE: Electricity meter pulse reading - octavvian - 10-03-2022 (06-23-2022, 03:08 PM)wilkxt napisał(a):(06-20-2022, 08:18 PM)v4v napisał(a): Hi, it is possible to read pulses from LE-02d MID electricity meter? (SW 1.49d | HW 3.8) Pulse output SO + SO- open collector so voltage and current is not important in this case, no?! ~open collector~ no voltage provided, voltage you must supply.... Hoped I'm not OFF-TOPIC... RE: Electricity meter pulse reading - wilkxt - 10-03-2022 So connect LK inpud directly to S0+, SO- and set in Lk inputs Pull-UP RE: Electricity meter pulse reading - bessieelliot - 06-05-2023 A 510om resistor on the INPDx input should work. vampire survivors RE: Electricity meter pulse reading - ulnaanticipate - 07-14-2023 Reading pulses from the LE-02d MID power meter is not a default function of this product. However, you can use a resistive voltage divider to reduce the magnitude of the input signal so that it matches the range of the meter.geometry dash unblocked |
