Issue with LK3.5 and firmware update - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V3.5 (https://forum.tinycontrol.pl/forumdisplay.php?fid=28) +--- Wątek: Issue with LK3.5 and firmware update (/showthread.php?tid=2161) |
Issue with LK3.5 and firmware update - georgec - 10-29-2021 I have a lan controller hw version 3.5 and until today has software version 1.24. I have tried to update it at version 1.45b with service jumper on like in the documentation and LKTools on Linux (I am aware with this operation, I successful made this before on other controllers also on Linux). The update was made (aparently) successful but after restart without jumper the controller never started and most strange thing is that it can't be reseted. In fact if I try to reset it at factory defaults I hear the 3 relay sounds like in the documentation but after that the controller still remain inaccessible through the factory ip. The only particularity of the operation was that the controller had at the moment of update other ip than the default with /16 mask. What should I do in this case? Is totally broken? Thanks, RE: Issue with LK3.5 and firmware update - wilkxt - 10-29-2021 In 1.45b firmware, default is DHCP on, so LK get IP from your router DHCP. Check in router what ip LK get. RE: Issue with LK3.5 and firmware update - georgec - 11-01-2021 Hey Tomek, You are right. This saved my day, thank you for your answer. |
