Relay direct control via HTTP - Wersja do druku +- Forum Tiny Control Solution (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler - wersje oprogramowania (https://forum.tinycontrol.pl/forumdisplay.php?fid=4) +--- Wątek: Relay direct control via HTTP (/showthread.php?tid=118) |
Re: Relay direct control via HTTP - sms.agent - 04-11-2013 Yes, in 2.39 it worked too. Re: Relay direct control via HTTP - wilkxt - 04-11-2013 check the settings, because the difference between 2.39 and 2.40 is very small and does not affect NTP, and in my LK (2.40) NTP works ok. If you are not using the watchdog you can try check this http://tinycontrol.ats.pl/forum/viewtopic.php?f=2&t=3031 version, it has more options |
